  • 发表于 2020-9-12 21:39:30 | 显示全部楼层
    我的M6600Q 按教程强刷了 ts150  s06的BIOS,开机只是开关灯亮,CPU有发热,然后我又刷了 P320 还是一样。然后我重新刷回原来编程器备份的BIOS,依然不能开机。然后爬贴看到174# 说到
    联想官网提供的下载仅仅是升级档,大小只有8M即BIOS Region部分,不包含ME部分。由于ME的关系,即使手上有其他同型号的机器的备份,刷入后依旧是不能正常工作的。解决的方法大概说一下,就是自己用fit工具处理,用纯净的同版本ME替换掉备份里的ME模块,重新上电ME状态会变成Initialized,此时才能正常工作。解决方法详细描述D大已多次贴出原帖地址,只是由于全英文,看起来有些许费力,有兴趣的可以找i来看看。
    然后尝试替换win-raid论坛上的全版本me包的ME,用的fit 替换完BUILD的时候报错
    Loading D:\BIOS\m6600qBackup.bin
    Decomposed SKU Value: "Intel (R) H Series Chipset - Intel (R) Q170 - Desktop".
    Decomposed PCH Strap Length: 0x58
    Warning: Could not set "GbE Read Access" to: 0x00000008, reverting to previous/default value: 0xFFF
    Warning: Could not set "Embedded Controller Write Access" to: 0x00000020, reverting to previous/default value: 0xFFF
    Warning: Could not set "Embedded Controller Read Access" to: 0x00000020, reverting to previous/default value: 0xFFF
    Decomposed VSCC 0x20252025 does not match default VSCC 0xFFFFFFFF.  Forcing to default.
    Warning: The ME FW image loaded has been pulled from a previously booted system. Some FW settings will not be allowed to be changed.
    Writing map file D:\Coffee_Lake_Mod_Tool_2019.1229\bin\m6600qBackup\m6600qBackup.map
    Loading D:\BIOS\11.0.2.1003_COR_H_D_PRD_EXTR.bin
    Warning: Invalid value specified for "BCLK SSC Changes Allowed": This parameter is not configurable for this profile type., reverting to previous/default value: Yes
    Warning: Invalid value specified for "BCLK SSC Halt Allowed": This parameter is not configurable for this profile type., reverting to previous/default value: Yes
    Writing map file D:\Coffee_Lake_Mod_Tool_2019.1229\bin\11.0.2.1003_COR_H_D_PRD_EXTR\11.0.2.map
    Executing pre-build actions
    Error 22: [FitActions] Invalid VSCC entry. Couldn't find a historic value for entry "VsccEntry", Vendor ID: "0xF8"
    Error 5: [CsmeBinaryGen] Error executing pre-build actions.
    Error 15: Failed to build.
    Failed to build!
  • 发表于 2020-9-12 21:44:11 | 显示全部楼层
    这是我编程器备份的原始bios 链接: https://pan.baidu.com/s/1U05p-5IHnYXKufIbggOqvg 提取码: qpnn
    其中有几个notwork.bin是我刷入后启动不成功我又用编程器读取后的bin,发现刷入的bin和重启后再读取的bin,会有差别,我想应该是刷入后启动时me自己就会有改动了。
  • 发表于 2020-9-13 00:10:35 | 显示全部楼层
    更新 恢复原来的 BIOS了。继续折腾。
    https://www.win-raid.com/t1658f3 ... tialization-12.html 第184楼 解决替换ME 后build 的错误。 现在刷入备份开机了。
    oh yeah 继续折腾
    多谢 我也遇到这问题 ,删除就好了。 他后面提到 您需要找到系统具有的 SPI 芯片,从制造商那里查找其数据表,并查看其供应商 ID 和设备 ID  发表于 2020-10-30 08:10
  • 发表于 2020-9-18 23:29:17 | 显示全部楼层
    D大,这个 帖子里没有M920X的选项,920x的bios是M1U开头的,要怎么弄呀,谢谢了
    而且920x是双bios 一个8M ,一个16M
  • 发表于 2020-9-18 23:48:44 | 显示全部楼层
    而且920x是双bios 一个8M  ...
    920x原生支持8-9代 你是要倒回去吗??
  • 发表于 2020-9-19 10:08:39 | 显示全部楼层
    是想上魔改U,比如ql3x   8850h之类的
  • 发表于 2020-9-19 17:58:11 | 显示全部楼层
    es也是支持的呀
    发表于 2020-9-26 00:31:02 | 显示全部楼层
    shuipuyue 发表于 2020-6-4 10:47
    D大你好,m710q按教程刷完以后可以点亮(亮机时间有点长),但出现风扇检测失败,屏幕提示cpu fan failur ...
    请教下大佬,我这边有一台M910Q也想上QL3X具体是要怎么弄?
  • 发表于 2020-10-6 11:12:54 | 显示全部楼层
    710q到手就测试刷bios上9代
  • 发表于 2020-10-8 10:16:37 | 显示全部楼层
    m710q到了就试试
  • 发表于 2020-10-16 12:57:24 | 显示全部楼层
    https://www.win-raid.com/t1658f39-Guide-Clean-Dumped-Intel-Engine ...
    最后成功了吗
  • 发表于 2020-10-18 23:58:10 | 显示全部楼层
    成功了。3x可以
  • 发表于 2020-10-19 21:34:02 来自手机 | 显示全部楼层
    tanpengsccd 发表于 2020-10-18 23:58
    成功了。3x可以
    请教一下,我是刚买了710q上3x,用了D大的软件然后关闭ME后正常点亮,但是内存只能插第一条内存槽,单插第二内存槽或者插两条都会报警无法开机,请问你有碰到过吗?这是3x的原因还是bios的问题
    发表于 2020-10-20 12:27:17 | 显示全部楼层
    D大,我的主板是Q170,按您的教程。操作完后可以支持7代CPU,不过现在再系统里点重启,机器不亮。必须断电后,再插电,开机才可以。。请问这个如何解决。。
  •  楼主| 发表于 2020-10-20 12:49:36 来自手机 | 显示全部楼层
    love1810 发表于 2020-10-20 12:27
    D大,我的主板是Q170,按您的教程。操作完后可以支持7代CPU,不过现在再系统里点重启,机器不亮。必须断电 ...
    在你回复的时候,帖子里没有关于Q170的内容吧?
