查看: 27190|回复: 36
Windows 7 SP1 X64 更新方案,无冗余
  • 发表于 2020-3-1 12:54:06 | 显示全部楼层 |阅读模式
    本贴为原创,首发于smxdiy论坛,如需转载请标明作者及出处
    前言:
    本贴基于http://www.smxdiy.com/thread-2420-1-1.html帖子中使用KB3125574的方案进行改进
    由于有些人不喜欢微软的KB3125574,所以本次讨论不使用KB3125574后续补丁更新方案
    理论上KB3125574是诸多补丁的汇集包,所以3125574包括的补丁必然存在冗余,所以我使用倒叙装补丁方法,在原版镜像的基础上集成上个方案中除KB3125574以外的其他补丁,然后用Windows Update搜索更新
    这里要感谢abbodi1406大神维护的win7更新库,从更新日志得知KB3021674被KB4537820取代
    同时还要感谢abbodi1406大神开发的BypassESU-AIO,可以离线集成ESU补丁,使Windows Update不再搜出已经被取代的冗余补丁,结合ESU补丁,形成了最终方案
    正文:
    1.
    KB4490628
    KB982018
    KB2479943
    KB2491683
    KB2506014
    KB2506212
    KB2506928
    KB2545698
    KB2547666
    KB2552343
    KB2560656
    KB2564958
    KB2574819
    KB2579686
    KB2592687
    KB2603229
    KB2604115
    KB2620704
    KB2621440
    KB2631813
    KB2640148
    KB2654428
    KB2660075
    KB2667402
    KB2670838
    KB2685811
    KB2685813
    KB2690533
    KB2698365
    KB2705219
    KB2719857
    KB2726535
    KB2727528
    KB2729094
    KB2732059
    KB2736422
    KB2742599
    KB2750841
    KB2761217
    KB2770660
    KB2773072
    KB2786081
    KB2791765
    KB2799926
    KB2800095
    KB2807986
    KB2808679
    KB2813430
    KB2830477
    KB2834140
    KB2840631
    KB2843630
    KB2847927
    KB2852386
    KB2853952
    KB2857650
    KB2861698
    KB2862330
    KB2864202
    KB2868038
    KB2871997
    KB2884256
    KB2891804
    KB2893294
    KB2893519
    KB2894844
    KB2900986
    KB2908783
    KB2911501
    KB2912390
    KB2918077
    KB2919469
    KB2923545
    KB2931356
    KB2937610
    KB2943357
    KB2968294
    KB2970228
    KB2972100
    KB2972211
    KB2973112
    KB2973201
    KB2977292
    KB2978120
    KB2978742
    KB2984972
    KB2985461
    KB2991963
    KB2992611
    KB3004375
    KB3006121
    KB3006137
    KB3010788
    KB3011780
    KB3013531
    KB3020370
    KB3020388
    KB3023215
    KB3030377
    KB3035126
    KB3037574
    KB3045685
    KB3046017
    KB3046269
    KB3054476
    KB3059317
    KB3060716
    KB3067903
    KB3071756
    KB3072305
    KB3074543
    KB3075226
    KB3078667
    KB3086255
    KB3093513
    KB3097989
    KB3102429
    KB3107998
    KB3108371
    KB3108664
    KB3109103
    KB3109560
    KB3110329
    KB3122648
    KB3126587
    KB3127220
    KB3133977
    KB3137061
    KB3138378
    KB3138612
    KB3138910
    KB3139398
    KB3139914
    KB3140245
    KB3147071
    KB3156016
    KB3159398
    KB3161102
    KB3161949
    KB3172605
    KB3179573
    KB3184143
    KB4019990
    KB4474419
    KB4555449
    2.安装IE11
    Internet Explorer 11
    IE-Hyphenation-en
    IE-LangPack-zh-cn
    IE-Spelling-en
    3.安装 BypassESU-v7
    KB4528069
    使用BypassESU-v7一定要注意,输入挂载路径的时候一定要用"\"符号,而不是"/",如果使用"/"符号,bypassESU只能执行到第一步,第二步无法执行,从而造成Windows Update搜出冗余补丁
    4.安装ESU补丁
    KB4538483
    KB4552940
    KB4556836
    可以使用KB4054998取代KB2973112和KB3122648,但是这补丁本身也被后续补丁取代了,但是如果不装KB4054998,微软就会推送KB2973112和KB3122648
    同时添加以下注册表:
    去除过时的net framework补丁:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\QualityCompat]
    "cadca5fe-87d3-4b96-b7fb-a231484277cc"=dword:00000000
    关闭遥测(三个没有):
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\EOSNotify]
    "DiscontinueEOS"=dword:00000001
    可选注册表:
    IE11字体修复方法:
    将win10的Fonts文件夹的msyh.ttc和msyhl.ttc文件放入win7对应的Fonts文件夹,同时集成以下注册表(在线修复无需注册表):
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts]
    "微软雅黑 & Microsoft Yahei UI (TrueType)"="msyh.ttc"
    "微软雅黑 Light & Microsoft YaHei UI Light (TrueType)"="msyhl.ttc"
    关闭幽灵熔断补丁:
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]
    "FeatureSettingsOverride"=dword:00000003
    "FeatureSettingsOverrideMask"=dword:00000003
    禁用恶意软件删除工具推送:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\MRT]
    "DontOfferThroughWUAU"=dword:00000001
    Windows Defender 无法在线更新病毒库:
    直接删除C:\ProgramData\Microsoft\Windows Defender\Definition Updates下所有文件即可
    附上最终效果图:
    剩余未集成的补丁为:
    KB976932    实际为KB2533552,被KB4490628取代,无法离线集成,为WU的bug
    KB4493132  Windows7服务终止通知(旗舰版专属)
    KB3021917  系统诊断和遥测以升级到win10
    KB3068708  更新以提高遥测质量和诊断
    KB3080149  CEIP和遥测诊断更新
    KB3150513  更新了兼容性诊断配置
    如果用一张图来形容这套方案,我想应该是这个:
  •  楼主| 发表于 2020-3-13 13:20:05 | 显示全部楼层
    2020/03/13:使用KB4540688取代了KB4537820,KB4550735取代了KB4537829
    2020/04/15:使用KB4550964取代了KB4540688,KB4550738取代了KB4550735
    2020/05/31:使用KB4556836取代了KB4550964,KB4555449取代了KB4550738,KB4552940取代了KB4532945,增加了BypassESU-v6,将KB2533552视为冗余
  • 发表于 2020-3-1 17:33:04 | 显示全部楼层
    感谢分享,能够提供补丁包更完美
  • 发表于 2020-3-3 01:41:00 | 显示全部楼层
    ddpt1626 发表于 2020-3-1 17:33
    感谢分享,能够提供补丁包更完美
    win7补丁包在香港一个论坛有下载
  • 发表于 2020-3-3 17:41:13 | 显示全部楼层
    蓝风sy 发表于 2020-3-3 12:55
    链接:https://pan.baidu.com/s/1nOA4w540AmFcnWob5c__yg
    提取码:e3cq
    未提供KB4537820,可自行在catal ...
    感谢分享
  • 发表于 2020-3-6 09:08:47 | 显示全部楼层
    KB3033929 SHA256补丁没加进去,还有NVME的两个补丁
  •  楼主| 发表于 2020-3-6 10:40:09 | 显示全部楼层
    KB3033929是很老的SHA256补丁了,已经被KB4474419-V3取代了,NVME补丁没列进去是因为update搜不到,不具有普遍性,需要NVME驱动的直接自行注入厂家专用的即可
  •  楼主| 发表于 2020-3-6 10:52:56 | 显示全部楼层
    https://support.microsoft.com/zh ... or-windows-and-wsus
    微软常见问题解答里回答了这个问题
  • 发表于 2020-3-6 11:34:07 | 显示全部楼层
    感谢分享,能够提供补丁包更完美
  • 发表于 2020-3-6 22:14:54 | 显示全部楼层
    大佬,过来支持你了~
  • 发表于 2020-3-9 09:11:51 | 显示全部楼层
    蓝风sy 发表于 2020-3-6 10:40
    KB3033929是很老的SHA256补丁了,已经被KB4474419-V3取代了,NVME补丁没列进去是因为update搜不到,不具 ...
    知道了,谢谢老大
    发表于 2020-3-9 14:36:32 | 显示全部楼层
    感谢分享,能够提供补丁包更完美。
  • 发表于 2020-3-13 14:27:47 | 显示全部楼层
    win7最终版、终结版(决定版)……
  •  楼主| 发表于 2020-3-13 15:10:53 | 显示全部楼层
    wufuwen 发表于 2020-3-13 14:27
    win7最终版、终结版(决定版)……
    还没终结呢,毕竟现在能装ESU补丁了,还能再挺三年
  • 发表于 2020-3-17 01:08:28 | 显示全部楼层
    建议,制作一个版本,方便大家测试去冗余后的情况。
