查看: 1478|回复: 3
两个批处理怎么合成一个SetupComplete.cmd
  • 发表于 2021-11-12 19:26:45 | 显示全部楼层 |阅读模式
       @echo off
    echo. & echo     *   驱动安装正在进行(请勿关闭本窗口)   *
    if exist %SystemRoot%\Setup\Scripts\YH.reg regedit /s %SystemRoot%\Setup\Scripts\YH.reg
    start /wait %SystemRoot%\Setup\Scripts\123.exe /A
    start /wait %SystemRoot%\system\OOBE.CMD
    rd /s /q %Windir%\Setup\Scripts 1>nul 2>nul
    DEL /F /Q %windir%\Panther\unattend.xml >nul
    RD /Q /S %windir%\Panther >nul
    del%0                                                     -----------------------------------------------------------------分割线上面1下面2                 @echo off
    IF EXIST C:\SWTOOLS RD /Q /S C:\SWTOOLS
    IF EXIST "%Systemroot%\Setup\OEMFILES" RD /Q /S %Systemroot%\Setup\OEMFILES
    IF EXIST "%Systemroot%\Setup\AIDA64" RD /Q /S %Systemroot%\Setup\AIDA64
    IF EXIST "%SYSTEMDRIVE%\AIDA64 REPORTS" RD /Q /S "%SYSTEMDRIVE%\AIDA64 REPORTS"
    IF EXIST "%SYSTEMDRIVE%\DRV64" RD /Q /S "%SYSTEMDRIVE%\DRV64"
    IF EXIST "%SYSTEMDRIVE%\DRV32" RD /Q /S "%SYSTEMDRIVE%\DRV32"
    IF EXIST "%SYSTEMDRIVE%\DRV" RD /Q /S "%SYSTEMDRIVE%\DRV"
    IF EXIST "%WINDIR%\System32\DepX64.exe" del /f /q "%WINDIR%\System32\DepX64.exe"
    IF EXIST "%WINDIR%\System32\DepX86.exe" del /f /q "%WINDIR%\System32\DepX86.exe"
    START /WAIT /B cscript /file:///C:\Users\Administrator\AppData\Roaming\Tencent\QQTempSys\OOY5$4OW5H`8`9%(9$)T67M.giflogo %Systemroot%\system32\slmgr.vbs -xpr | findstr /I "计算机已永久激活" && GOTO ENDALL
    START /WAIT /B cscript /file:///C:\Users\Administrator\AppData\Roaming\Tencent\QQTempSys\OOY5$4OW5H`8`9%(9$)T67M.giflogo %SYSTEMROOT%\system32\slmgr.vbs -xpr | findstr /I "The machine is permanently activated" && GOTO ENDALL
    WMIC PARTITION | findstr /i "GPT"
    IF NOT ERRORLEVEL 1 GOTO GPT
    %~dp0"Windows Loader.exe" /silent /preactivate
    cd %~dp0
    attrib -R -A -S -H *.*
    SHUTDOWN /R /T 6
    RMDIR /S /Q "%WINDIR%\Setup\Scripts"
    exit
    :GPT
    START /WAIT /MIN %~dp0"efi.cmd"
    cd %~dp0
    SHUTDOWN /R /T 6
    exit
    :ENDALL
    cd %~dp0
    exit        把里面Windows Loader.exe换成123.exe /A合并在一起保存为SetupComplete.cmd
  • 发表于 2021-11-14 23:40:15 | 显示全部楼层
      @echo off
    cd %~dp0
    SHUTDOWN /R /T 6
    exit
    :GPT
    cd %~dp0
    SHUTDOWN /R /T 6
    exit
    :ENDALL
    cd %~dp0
    exit
  •  楼主| 发表于 2021-11-15 10:46:07 | 显示全部楼层
    2224354981 发表于 2021-11-14 23:40
    @echo off
    想问下这样就可以了吗
  • 发表于 2024-3-7 08:31:05 | 显示全部楼层
    echo 里的是驱动安装?不是急火么? 这是在部署时运行的吧?那个阶段appdata文件夹是生效的吗?跑QQ文件夹内确认急火信息?
