成长值: 0 TA的每日心情 | 闭嘴 昨天 22:26 |
链接: https://pan.baidu.com/s/1c8SJDtchAjVO3Z7mIOLsqg 提取码: BIOS
如何刷入此处不再赘述,刷入时请确保 Flash Descriptor、ME Region 和 BIOS Region 都被正确刷入。
其他传送门:
华擎 ASRock Z170/M OC Formula 超频方程式 Coffee Lake Mod BIOS
http://www.smxdiy.com/thread-977-1-1.html
华擎 ASRock DeskMini 110 系列 Coffee Lake & Xeon & BGA1440 Mod BIOS
http://www.smxdiy.com/thread-887-1-1.html
华擎 ASRock 200 系 主板 Coffee Lake & Xeon & BGA1440 Mod BIOS(注:H110M-G/M.2 在此贴内)
http://www.smxdiy.com/thread-906-1-1.html
华擎 ASRock 300 系 22nm PCH 主板 Xeon & BGA1440 Mod BIOS
http://www.smxdiy.com/thread-1001-1-1.html
永擎 ASRock Rack C232/C236 系列主板 Coffee Lake Mod BIOS
http://www.smxdiy.com/thread-1168-1-1.html
支持型号及基于何版本修改:
1 | B150 Combo | 7.30 | 2 | B150 Gaming K4 | 7.30 | 3 | B150 Gaming K4/D3 | 7.30 | 4 | B150 Gaming K4/Hyper | 7.30 | 5 | B150 Pro4/3.1 | 7.30 | 6 | B150 Pro4/D3 | 7.20 | 7 | B150A-X1 | 7.30 | 8 | B150A-X1/Hyper | 7.40 | 9 | B150M Combo-G | 7.10 | 10 | B150M Pro4 | 7.30 | 11 | B150M Pro4/D3 | 7.10 | 12 | B150M Pro4/Hyper | 7.30 | 13 | B150M Pro4S | 7.20 | 14 | B150M Pro4S/D3 | 7.10 | 15 | B150M Pro4V | 7.20 | 16 | B150M-DVS R2.0 | 7.50 | 17 | B150M-HDS | 7.50 | 18 | B150M-HDV | 7.30 | 19 | B150M-HDV/D3 | 7.10 | 20 | B150M-ITX | 7.10 | 21 | B150M-ITX/D3 | 7.10 | 22 | B150M-PIO | 7.40 | 23 | B150M-PIO2 | 7.30 | 24 | E3V5 Performance Gaming/OC | 7.50 | 25 | E3V5 WS | 7.30 | 26 | H110 Pro BTC+ | 1.60 | 27 | H110M Combo-G | 7.20 | 28 | H110M-DGS | 7.70 | 29 | H110M-DGS R2.0 | 7.60 | 30 | H110M-DGS R3.0 | 7.50 | 31 | H110M-DGS/D3 | 7.30 | 32 | H110M-DS/Hyper | 7.30 | 33 | H110M-DVP | 7.30 | 34 | H110M-DVS R2.0 | 8.00 | 35 | H110M-DVS R3.0 | 7.40 | 36 | H110M-DVS/D3 | 7.20 | 37 | H110M-GL/D3 | 7.20 | 38 | H110M-HDS | 7.50 | 39 | H110M-HDS R3.0 | 7.40 | 40 | H110M-HDV | 7.60 | 41 | H110M-HDV R3.0 | 7.50 | 42 | H110M-HDV/D3 | 7.20 | 43 | H110M-HDVP | 7.40 | 44 | H110M-HDVP2 | 7.50 | 45 | H110M-HG4 | 7.50 | 46 | H110M-I | 7.30 | 47 | H110M-ITX | 7.20 | 48 | H110M-ITX/ac | 7.20 | 49 | H110M-ITX/D3 | 7.20 | 50 | H110M-PIO | 7.40 | 51 | H110TM-ITX | 7.30 | 52 | H110TM-ITX R2.0 | 7.30 | 53 | H170 Combo | 7.40 | 54 | H170 Performance | 7.20 | 55 | H170 Performance/D3 | 7.30 | 56 | H170 Performance/Hyper | 7.30 | 57 | H170 Pro4 | 7.30 | 58 | H170 Pro4/D3 | 7.20 | 59 | H170 Pro4/Hyper | 7.30 | 60 | H170 Pro4S | 7.40 | 61 | H170A-X1 | 7.40 | 62 | H170A-X1/3.1 | 7.40 | 63 | H170M Pro4 | 7.20 | 64 | H170M Pro4S | 7.20 | 65 | H170M-ITX/ac | 7.10 | 66 | H170M-ITX/DL | 7.10 | 67 | Q170M vPro | 7.40 | 68 | Q170M vPro+ | 7.30 | 69 | Z170 Extreme3 | 7.50 | 70 | Z170 Extreme4 | 7.51 | 71 | Z170 Extreme4+ | 7.40 | 72 | Z170 Extreme6 | 7.50A | 73 | Z170 Extreme6+ | 7.40 | 74 | Z170 Extreme7+ | 7.60 | 75 | Z170 Gaming K4 | 7.30 | 76 | Z170 Gaming K4/D3 | 7.30 | 77 | Z170 Gaming K6 | 7.50 | 78 | Z170 Gaming K6+ | 7.50 | 79 | Z170 Gaming-ITX/ac | 7.30A | 80 | Z170 Pro4 | 7.50 | 81 | Z170 Pro4/D3 | 7.30 | 82 | Z170 Pro4S | 7.50 | 83 | Z170 Professional Gaming i7 | 7.50 | 84 | Z170A-X1 | 7.30 | 85 | Z170A-X1/3.1 | 7.20 | 86 | Z170M Extreme4 | 7.40 | 87 | Z170M Pro4 | 7.40 | 88 | Z170M Pro4S | 7.40 | 89 | Z170M-ITX/ac | 7.20B | 90 | Z170M-PIO2 | 7.20 |
“ME正常启用”版的修改内容:
- 微码 506E0(0x18),506E1(0x2A),506E3(0xBA),506E8(0x34),906E9(0x5E),906EA(0x96),906EB(0x5E),906EC(0x98),906ED(0xBE)
- 核显 GOP 更新到 9.0.1107 版本
- 核显 GOP VBT 更新到 228 版本
- 核显 VBIOS 更新到 1062 版本
- 补全 DSDT 和 SSDT 里面的 16 个逻辑 CPU(在不使用 iasl 反编译的情况下)
- 修改 前4个核心的倍频同步至后4个核心(意思就是BIOS 内支持对全核倍频的超频,设置为 Sync All Core 模式即可)
- 修改 ME 版本为 11.7.0.1261
- 修改 Intel PHY 网卡默认 MAC 地址,避免 88-88-88-88-87-88 带来的问题
- 修改 解锁原本隐藏的部分超频选项
- 修改 除 H110 Pro BTC+ 外的其他 8 MB BIOS 容量主板,BIOS 界面背景为纯黑,以放入更多的 CPU 微码
此版本 BIOS 不支持任意 Xeon 志强系列的 CPU(无论是原生 LGA1151 还是 BGA1440 转接 LGA1151),官方同版本 BIOS 亦是如此。
此版本 BIOS 不支持任意 6 代正式版及更新的 BGA1440 转 LGA1151 的 CPU,官方同版本 BIOS 亦是如此。
此版本 BIOS 支持其它上文没有提到的 CPU。
对于采用 C232 PCH 的主板(即 E3V5 Performance Gaming/OC 和 E3V5 WS)来说:
此版本 BIOS 不支持 10 代正显和正式版的 BGA1440 转 LGA1151 的 CPU,官方同版本 BIOS 亦是如此。
- 修改 ME 版本为 11.8.93.4323 精简版并禁用
- 修改 Flash Descriptor 内所有 Region 的读写权限为无限制
- 修改 最大 DRAM 限制为 128 GB(原本为 64 GB)
额外的:
对于 Z170、Hyper 和 OC 系列的主板,CPUID 为 506E3 的微码采用 0x74 版本;
对于下列主板:
B150A-X1
B150A-X1/Hyper
B150 Pro4/3.1
H110M-DGS/D3
H110M-DS/Hyper
H110M-ITX
H110M-ITX/ac
H110TM-ITX R2.0
移除了部分 IPv6 相关模块:
5BEDB5CC-D830-4EB2-8742-2D4CC9B54F2C Ip6Dxe
D912C7BC-F098-4367-92BA-E911083C7B0E Udp6Dxe
95E3669D-34BE-4775-A651-7EA41B69D89E Dhcp6Dxe
99F03B99-98D8-49DD-A8D3-3219D0FFE41E Mtftp6Dxe
对于下列主板,移除了 768BEDFD-7B4B-4C9F-B2FF-6377E3387243 NTFS 模块:
H110M-DS/Hyper
H110M-ITX
H110M-ITX/ac
LGA1151 的 Xeon 处理器需要 C2xx 系列 PCH 才可以启动,普通 H/B/Z 系 PCH 会被 ME 拒绝启动。同理,BGA1440 的 CPU 也需要 HM/CM 系 PCH 才能正常启动,转接到 LGA1151 以后也会被 ME 拒绝启动。若想突破限制,在 100/200 系这一代,就是修改 ME 进入 Alt Disabled 模式,且 ME 固件也要使用特定的版本。另外,在这些 22nm PCH 的平台安装有 128 GB 内存时,ME 也无法正常启动,不禁用 ME,通电到 BIOS 自检的时间会非常久。此版本 BIOS 做了相关的改动,以支持 128 GB 内存和原本与 PCH 不兼容的 CPU。
ME 禁用后,依赖 ME 的功能无法使用(包括但不限于HDCP、Intel TXT、Intel SGX、Intel PTT(fTPM)、黑苹果核显休眠唤醒、无外置时钟发生器时的外频调节等),这些 BUG 我无法解决,亦不要反馈。
由于 BIOS 原本为 4 核心 CPU 设计,即使破解支持新 CPU,BIOS 内的选项也只能调节前 6 个核心(如 Active Processor Cores)或前 4 个核心(如 Core Ratio Limit),这个不是 BIOS 的 BUG,我没有 BIOS 源代码,无法加入对应的选项,这方面问题不要反馈给我。
但对于超频需求,已经修改过,使用 All Core 模式对全核心倍频进行超频时,可以正常控制全部六个或八个核心的倍频。
Z170 的 BIOS,基本上 2017 年以后,内存相关就没有再更新过了,缺少对新时代内存颗粒超频的支持,若采用新颗粒调节超频,需要手动逐项填写第二、第三时序后才有超频成功的可能性,这方面我没有研究,也不是 BIOS 的 BUG,不要反馈给我。
对于 8/9 代非 B0 步进(所有六核及以上都不是 B0,只有一部分双核与四核是 B0)的原生 LGA1151 的 CPU 需要屏蔽 2 点(AJ30 与 AK27)、短接 2 点(AB35 与 AC35,确保底座上这 2 根针导通即可,CPU 上这 2 个触点不作要求,导通与否均可,也没有危险性)再上机。也可以屏蔽更多(额外的还有F35,F36,F37,G34,G35,H33,H34,J33,J35,K32,K34,L31,L33,M32,AJ22,AJ24,AK21,AK22,这些屏蔽与否均可,在 100/200 系主板屏蔽这些针脚不会对 CPU 的功能造成任何影响)。其他没有提到的 CPU 无需对针脚进行修改。针脚定义及坐标位置请参阅 Intel 官方文档,感兴趣的还可以看看我这篇帖子:LGA1151魔改触点/针脚处理指南 |
